Two Questions 4 U-Yes, I said You!
Old Mar 25, 2003 | 07:50 PM
ImportKi11er's Avatar
Thought that would get your attention I just bought a1988 Camaro SC about 3 weeks ago, as a summer builder/project car. I was told that the guy that had it before swapped in a L98 out of a Trans-Am, but junked the TPI in favor of the TBI unit off from the original LO3. My first question is, what visual differences besides the fuel systems are there to tell a L98 and a LO3 apart? And second of all; sometimes my engine will start fine, but other times it will start then quit, or then start and idle at 200 rpm-on the brink of dieing. Lately it has been doing just fine, since I sprayed TBI cleaner in it, but if I floor it from idle, it bogs as though it's not getting enough fuel. I replaced the pressure regulator, but it didn't make much of a difference. Any ideas on either of these problems will greatly help out another Camaro fan.
:hail: Raw Power
Old Mar 25, 2003 | 07:51 PM
CrispyClutch's Avatar
Hey before you throw that tpi stuff away I've been looking for a cheap TPI setup...
Old Mar 25, 2003 | 07:56 PM
The owner before me took the tpi system off and put the tbi on...I don't have it. Not even sure if this is an L98...it runs like a 350, a starved 350 but never the less a 350. I'm not sure if I have a L98 with a LO3's TBI system(very likely), or just a stuttering LO3.
Old Mar 25, 2003 | 08:42 PM
Keith27's Avatar
Get the casting numbers off the block...
Old Mar 25, 2003 | 10:14 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
check the casting numbers
www.mortec.com
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
