no fuel?
Old Apr 8, 2003 | 06:20 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
no fuel?
i'm looking to buy another project car. its an 87 TBI with a 350 put in it.it soposedly runs but we couldn't get it to run today. it is at a junk yard(this one has some nice cars compared to others) they were trying to start it today because i would like to see it run before i buy it of course. first they sprayed carb cleaner in to try to start it and it would just chug but not start.(any1 heard or carb cleaner to start a car? they set it on fire twice, no damage though) i told them to use gas so they did, they used a spray bottle(luckily no fire this time) it would run at a real low rough idle if they sprayed while it was running. i nocited that the throttle bodies were closed all the way to the point they would stick closed. this is after they gave up and figured it needed a fuel pump, which they should have in by tomarrow. do you think the throttle was closed to much? (i'm not a TBI guy so i don't know if theres a weird valve in there to act as a choke or something)
if it isn't getting fuel where could it be most likely(i don't know much about electric fuel systems)and how hard is it to fix, any ideas?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
