how is this car waisting so much gas
Old May 4, 2003 | 07:47 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i have a 89 camaro 5.0 tbi,i put on an open elment filterfrom mr gaskets and my muffler at the back was remove because it was rusted.what could be the reason that i put 5 bucks in it and i drive for like 10 min and its gonna it never waisted this much gas.what can it be ?the muffler missing or the air filter?help me out guys
Old May 4, 2003 | 08:43 AM
JokerRS's Avatar
Car: 92RS
Engine: 357
Help me with the math. $5 / 10min =?mpg
Lets see if I got this right. New mod (open element), loud exhaust (no muffler), so I took it out and beat the snot out of it for ten minutes to see if it had anymore power now (also because it sounds so nasty whan I open it up), and it burned alot of gas.
I think theres something wrong with your car.
Check for a lose throttle nut.
Our gas gages fall real fast when they are below 1/4. You need to fill it up and check the mpg on your next tank full.
Then we would have a better guess if it was running right.
Old May 4, 2003 | 09:33 AM
JokerRS's Avatar
Car: 92RS
Engine: 357
Sory for being an azz. Did you remove the IAT senser (the thing with the wires hooked to it) from the old air cleaner housing and plug it back in. Did you plug the vacume port on the tbi where you disconected the vac line from the old air cleaner? If you did these things theres probably nothing wrong. Removing your muffler wont hurt your gas milage. Good luck.
Old May 4, 2003 | 11:03 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
If its running bad then it's probably a vacuum leak like Joker said. If its running ok, how many miles are on it and when was the last tune up? You're probably due for one as most 3rd gens are. Just use AC Delco OEM plugs, any decent set of 8mm wires (I like the moroso ones I just put on over my accel ones I used to have), new cap/rotor, new O2 sensor, and new pcv valve.
Old May 4, 2003 | 12:51 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
the sensor is in the new air cleaner the old vacumn was cover with a plug.they told me to check my computer to see if it gives me any codes.also i remove the pollution system and plug all the holes like from the headers and the cat is that the problem?oh and my injectors shoot rough not smooth i think that is it?
Old May 4, 2003 | 08:26 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
i did a ecm check and i got a code 44.this is lean exhaust what does that mean?help me out i cant afford waisting this much gas
1992 Trans Am
May 10, 2023 07:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
