Code 33, MAP voltage high/vac low
Old May 21, 2003 | 06:14 PM
Buck268's Avatar
OK, so simple question here. Is there any test I can run on the MAP sensor to determine whether I should replace or look for vacuum leaks? Or should I just hook a vacuum gauge (which I dont have) up?
Old May 23, 2003 | 01:37 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
As long as it's reading between 1 and 1.5 volts at idle and close to 5 volts at WOT then your MAP sensor is okay. You do not need a vaccum guage as long as there are no vaccum leaks between the throttle body and the map sensor or something else isn't wrong.
Later,
Harry
GTAman
Mar 15, 2019 11:40 AM
Cornholio7979
Sep 20, 2018 02:31 AM
GTAman
Sep 21, 2015 09:57 AM
