About fuel presure...
Old Jun 30, 2003 | 12:33 AM
Crisis's Avatar
Should the fuel presure stay up when i turn the power on?? (not starting)
I got to the track last weekend and ran a 16.4 @ 85mph / '60 2.47s
I started looking whats wrong since i thought i'd run high to mid 15's..
now.. when i turn the power on the fuel pump does go on. The fuel presure raises to 12.5psi which i set it to.. the presure stays there for about 3 seconds and then drops to 3 psi.. and slowly goes to 0 after that... is this normal?? or is the fuel pump leaking and not holding presure..
my trainy was sliping also but don't you think 16.4 is pretty slow for this set-up??
Old Jun 30, 2003 | 07:39 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
That is normal if your just turning the key to run. If it going low while the engine is running, you have a problem.
Old Jul 1, 2003 | 12:11 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I'd say work on your launch, if you got your sixty foot down to a 2.2xx range, you'd be close to the 15's if not in the 15's, good luck!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
