305 fuel pump
Old Jul 11, 2003 | 02:01 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
Urgent fuel pump question
I am getting a new fuel pump for my 1982 cfinjected 305.
I found this pump from the jegs website.
After reading about the 305 , the stock pump is electric and had a max of 13psi.
*I want to buy this pump below. I just wanted a last second clarification from anybody that this one should replace the stock one with no problems.Its from jegs.
''Blue'' Max-Pressure Pump
Perfect for ''race'' applications and is pre-set to approximately 14 psi. Flows 70 gph while maintaining 9 psi line pressure. Free-flow capacity is 110 gph. Includes Holley regulator, 510-12-803 and check valve and filter screen. 3/8'' NPT ports. Not for use with alcohol.
Old Jul 17, 2003 | 01:46 PM
Car: 82 T/A
by the way I just changed my fuel filter and all my stuttering problems are gone. I didnt know something that small can make such a difference. However the filter adapter leaked a bit so I had to smear industrial sealant near the top threads and had no more leaks.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
