another da#m thermostat question?
Old Jul 24, 2003 | 09:25 PM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
IIRC, you can take a thermostat and dip in water and it will open up. Is this correct. I am having bad over heating problems. The water pump is working and so is the fan, just wonderin' I could test the t-stat
Thanks Scoty
Old Jul 24, 2003 | 10:50 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
To test your t-stat you can drop it in a pot of boiling water and it should open up after a few minutes in the pot.
If you are having bad overheating problems there are a number of things to check for.
#1) Is the airdam (located underneath the front spolier) still there.
#2) What is the condition of the coolant?
New, fair , or rusty.
#3) Is the bottom hose going into the waterpump collapsing under temperature while doing higher revs of the engine. (this is a common problem) Replace old hose.
Those are a few things to look for.
Hope this helps.
Old Jul 25, 2003 | 06:52 AM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
Thanks for t he reply. The air dam is installed, I will check the bottom hose. The coolant right now consist mainly of water. I am going to check the t-stat and then get the cooling system flushed, and new coolant.
Scoty
italiano67
Dec 11, 2016 09:21 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
perZ
Aug 15, 2015 01:17 PM
