sensor gone?
Old Nov 9, 2003 | 11:54 AM
jordanz28ss's Avatar
sensor gone?
Hey guys, question for ya...I am not sure if there is a sensor gone or something is loose.
My check engin light will come on and stay on for a few minutes then shut off. and sometimes when cruising it feels like the car shuts off then comes back on...kinda like I loose all power then it comes right back..it doesn't do it all the time just every now and then...what could be the problem....thanks guys.
Jordan
Old Nov 9, 2003 | 12:53 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
Pull your trouble codes and go from there. There saved in the ECM even though the SES light dosen't stay on. You can do this with a paper clip, it be best to go to Auto Zone and get a "book" on your car it will explain how to pull the codes and things to check for each code.
Old Nov 9, 2003 | 01:04 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
While you're at auto zone pick up one of their free "GM Code Keys".. saves hunting for paper clips.
Also, "how to read your codes" is in the "Miscellaneous" section of the FAQ
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Old Nov 10, 2003 | 12:12 PM
thanks guys. I think I just had something loose....I moved the wires around and found some loose fittings and since then I have it has not been acting up and running good..
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
