Whats the lower limit on air/fuel ratios?
Old Nov 12, 2003 | 11:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
More of an engine question, but still quasi-tbi related since alot of us use highway mode whether we know it or not. What is the safe lower limit on AFR's at part throttle cruising? During highway operation, the ecm enters its highway mode and the 02's drop to almost nill. Just maybe 3 or 4 millivolts of return. Is it safe to run the motor this lean in cruise? I know around .1 volt is around 17:1 but it looks like im off the low end of the scale. What are the safe lower limits on fueling before my pistons are reduced to eight 4in. diameter blobs?
Old Nov 13, 2003 | 09:08 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
As far as i know, detonation is what destroys pistons. A lean tune is just fine so long as its not lean enough to cause lean misfire and your spark tables are tuned accordingly
Old Nov 13, 2003 | 10:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i have my hi-way mode set ot about 17.4:1, i have no detination issues.
what exactly are you o2 readings? i think i was your post on the diy board. IIRC .04mv is clean air for the o2 sensor.
Old Nov 13, 2003 | 12:12 PM
Car: 88 Camaro SC
Engine: SFI'd 350
my 02s (stock, not WB) are .004V. As a ballpark estimate, what should they be? Around ..07-.1 volt?
Old Nov 13, 2003 | 12:14 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i'd have plug in the laptop and get out on the hiway to check my o2 voltage once hi-way mode has come on. might be able to do that this weekend for you.
Old Nov 13, 2003 | 12:54 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
do you happen to know what stock is? roughly i mean.. i realize it'll proby vari a little....
and how low can you go?
Old Nov 13, 2003 | 01:02 PM
Dewey316's Avatar
Car: 1990 Camaro RS
haven't tried to see how low i can go.
depending on vacume it varied from like 15.6-17.1 stock. i bascily added 3thenth of a point across the board. it has worked fine. i really need to do some long term fuel millage testing, to see exactly what AFR the best millage can found at when using the HW mode.
Old Nov 13, 2003 | 04:54 PM
Car: 88 Camaro SC
Engine: SFI'd 350
JPrevost was nice enough to search my bin for my ecm and found the tables in a different spot. Assuming i set the addl. table up right in tuner cats tdf file, the AFRs are around 15.1:1 or so in my ecm and teh VE table is pretty close. What bothers me is that the fueling looks like its alot farther off then what the ecm is commanding. Maybe its those unkown pph holley injectors i have.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
