Gtech tuning?
Car: 91 Camaro RS
Engine: TBI
Gtech tuning?
wondering who uses the gtechs to tune or get ballpark hp ideas from they're rides? got one when i had the bird but never used it gotta get it out on the rs anyone have any tips for using em or whatever to get the best results.
Car: 1994 25th Anniversary Trans Am
Engine: Lt1
Transmission: A4
From what I've heard they're pretty accurate. I have one and it's a good tool to view some before/after results of mods. The 0-60 and 1/4 miles times are pretty accurate although I have heard that the trap speeds are usually off by 1-3mph(usually higher). Other than that they're an awesome tool. For your 0-60 all I can say is work on your launch. Try everything and go with what works best. For me personally I have found that if Ihold my left foot and the brake and bring the motor up to right before it feels like it's going to lurch forward and then give it as much gas as possible without getting spin. It's a bit of an art and is different for every car but as they say, practice makes perfect. Goodluck!
Car: 92RS
Engine: 357
I use one for tuning. I use the 0-60 to check results of minor changes to see if I'm going the right direction.the hp mode seems to be afected by how firm your shift is(auto trans).
Car: '85 Z28
Transmission: WC T5, 3.23 posi
They're pretty good for tuning from what I've heard. I'm going to use one to tune my car this spring, as well as going to the track. The speed on it is usually a few mph off, like cas said, but that's becasue it measures your speed at the 1/4 mile mark rather than at the track where they use a 60' trap to measure speed (how ever long it takes you to travel the last 60', and then they convert that to mph).
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Chuck!
That's how I planned to use mine. Common Spring!!
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
this is essentially the same procedure you use on a chassis dyno, except on the dyno you do it in a 1:1 gear. you do it in a lower gear on the gtech to minimize the effect of wind resistance.
i've found my g-tech to be fairly accurate, once it's set up properly.
the most important thing is to get the most correct weight possible for it. i weighed my car with me and a full tank of gas in it and saw the times get much more accurate.
you also have to be very careful when you calibrate the axis. i did mine on a table with a level. it helped a lot.
another place where you can make a difference is in the rollout setup. there's an extensive section on rollout in the manual. i set mine no higher than 2"
