A/C Delete Help
Old Dec 22, 2003 | 09:33 PM
JBert's Avatar
Car: Looking
A/C Delete Help
I spent an hour today at work today ripping all the A/C stuff out of the RS.
Now I'm left with the big A/C compressor bracket on the front of the block. Are there any companies that make an A/C delete kit for the 305, or does anyone have any "clean" ways to get rid of that hunk of useless metal?
Old Dec 22, 2003 | 09:53 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
There is an A/C delete pulley you can grab.....its not that expensive etc..soemthing like 35/40 bucks.....do some searching online here, I am sure you wont have a problem finding the part nubmer etc..
Old Dec 22, 2003 | 11:03 PM
JBert's Avatar
Car: Looking
thanks for the heads up- found the pn number for gmpartsdirect.
does anyone have pics of what it looks like installed?
will i need a shorter belt? (what size?)
thanks!
Old Dec 22, 2003 | 11:48 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I do not know if you need a shorter belt.. But any referance chart at a autoparts store should tell you that.. here is a pic I had on the harddrive of the AC Delete pully.. (My car)..
Attached Thumbnails A/C Delete Help-ac-delete.jpg
Old Dec 23, 2003 | 12:29 AM
JBert's Avatar
Car: Looking
thanks for the pic- helped me visualize what it would look like set up-
Old Dec 23, 2003 | 07:17 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
as for the belt....I dont think that you would/do need a shorter one...but I dotn really know because I still have that heavy old compressor on the front of my engine....just using it as a pulley on my engine...ac gone too
Old Dec 23, 2003 | 10:25 AM
vjo90RS8's Avatar
Car: 2002 Z28
no, you WONT need a shorter belt so dont even waste your money on one. Also since you are deleting your AC you might want to look for a non AC heater box which are less bulky than the AC one that sits on the passenger side of the side of the firewall. There are always some on ebay. It will really clean up the engine bay and make getting at that back spark plug or exhaust manifold/header bolt 100 times easier.
Old Dec 23, 2003 | 09:03 PM
JBert's Avatar
Car: Looking
Thanks for the help-
I ordered the part from gmpartsdirect-
now, its time to go find a non a/c heater box, and then to remove the smog stuff once my new headders come in
Old Dec 26, 2003 | 10:06 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
I got the A/C delete pulley for x-mas. It is very light. I'd say less than 3 pounds. Can't wait to put it on.
Laters,
Conrad
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
