Anybody ever used the Pro-jection manifold
Old Dec 28, 2003 | 05:31 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Has anybody used the Holley Pro-jection intake manifold? It says it's a dual plane, high rise intake and EGR compatible manifold for the 670 Holley.
Just wondering.
Old Dec 28, 2003 | 07:26 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A few members have but they had to convert to an older style EGR. No biggy though but I hear it is a great intake. Poeple just usualy don't like to justify the cost.
Old Dec 28, 2003 | 01:51 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I've got one that I plan on using with my 350 L98 swap soon.
Old Dec 28, 2003 | 03:38 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I helped a friend put it on with a 670. Its solid because you dont need an adaptor for tbi like I need with my rpm. He likes it, but he's got a lot of issues other than the manifold so he never really got any good times.
Old Dec 28, 2003 | 04:20 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
It's a great intake. I ran the intake on my 305 until it died. I would have it on my 383, except I'm running vortech heads. I swapped that intake (replacing the stock one) and swapped in some 1.6 roller tip rockers at the same time, and can say that it was the greatest sotp difference so far, besides the engine swap obviously. I actually felt it more than my gear swap.
The swap isn't that hard either, it's pretty much equivalent to a carb intake swap in that you only have one vaccum source and need to route the coolant hose from the diverter to the front of the manifold (looks better anyways). Both are easy to do.
The only issue is with the egr valve as shifty stated. To make the stock style work, you need to run a 5/8" tbi spacer. Doing so, you would probably need to modify the throttle bracket as well. Or you can try an older truck style egr from what I have heard. I ran a egr blockoff plate, and had it turned off in the chip.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
