Plenum Divider Kit
Old Jan 2, 2004 | 02:56 PM
dstefl's Avatar
Car: 91 RS
Engine: 305 TBI
Plenum Divider Kit
Is it necessary to use the plenum divider with TBI. Holley's website says that if you use a automatic trans you need a plenum divider for low RPM vacuum. What does vacuum have to do with a Automatic Trans?
This is for the Weiand 7525 single plane. Here is the link:
http://www.holley.com/HiOctn/ProdLin...MSCA/7460.html
Old Jan 2, 2004 | 06:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
no you shouldn't need it. using that will get rid of the benifits you see from going to the one large open plenum.
Old Jan 2, 2004 | 06:50 PM
dstefl's Avatar
Car: 91 RS
Engine: 305 TBI
Yeah, that is what i was thinking. I still don't really understand why you would want it with a automatic trans. Maybe because of a lack of throttle response with carbs in the low end.
Old Jan 2, 2004 | 11:21 PM
Dewey316's Avatar
Car: 1990 Camaro RS
remeber, TH350's and TH400's are hooked to vacume.
700r4's like 3rdgens have, are not.
Old Jan 3, 2004 | 08:44 AM
dstefl's Avatar
Car: 91 RS
Engine: 305 TBI
Oh, well that would make more sense then. Well it was ordered and it should be here wednesday! The intake was the last piece i needed, so the build-up will start next week. With a little luck i will be able to have it ready to go around march.
Thank you for all your help!
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Pinguiclia
Oct 12, 2015 04:47 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
