Fuel Only TBI system????
Old Jan 17, 2004 | 01:08 AM
tom85cj7's Avatar
Can I use a GM ignition module to filter the tach signal from my coil and create the reference signal required to fire the injectors? I would use one of the 8-pin Camaro style modules and only connect 12V+, GND, Coil(-), and use the PPL ref to the ECM. Does anyone know if this will work?
This is so I can run a TBI system without using the ignition control. I am using a duraspark/TFI ignition.
Thanks,
Tom
Old Jan 17, 2004 | 11:20 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Although I dont know how to do it it has been done before. Hopefully the person who did this will see this thread.
Old Jan 17, 2004 | 11:30 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Ah, just remembered the users SN. Its CHEVYTOWN. He was useing a non-CC dist. with his efi. Im not sure which one he was using but its worth a shot dropping him a line.
Old Jan 18, 2004 | 08:33 AM
tom85cj7's Avatar
Thanks for the replies. I actually figured this one out with some trial and error. Here is a wiring diagram for my AMC/Duraspark application, but it will work with any coil and distributor.
Later,
Tom
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
