TBI on 86 Chevy Heads
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
Got a set of HP heads, 2.02-1.60 valves but they have the earlier 86 manifold bolt patterns and wondered for now if I can get an adapter to use TBI?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by steve8586iroc
I believe you can elongate the four center bolt holes on the intake manifold and it should fit with no problem.
Steve
Steve
40 over 350-H345NP40 Fed Mogul Pistons
This is a strong running 93 4 bolt main 350, new HYP pistons and will use a .015-.018 Head gasket to get 67 cc even down more as around 64 cc, specs below: Heads are Pro Topline Torker's, chip was made for this but needed a least 9.0:1 compression, Never stock, should have bolt type of valve cover bolt holes-as World does and ad said should: (These are to replace wrong SR 76 cc heads sold to me as Torker 67 cc awhile back as I had a good set of stock 76 cc already-167-170 Runners!) Heads are a Pro Topline 2236720167-T and took forever to get right heads with right chambers as sold SR as these first, then got hurt/ill. Not sure how much I can push Compression on street motor as 67 cc heads and gasket can effect this say going from stock .041 to a .015-.020 should be helpful and any ideas welcomed and encouraged!
STL-H345NP40
Specifications:
* Bore: 4.040 in.
* Stroke: 3.480 in.
* Rod length: 5.700 in.
* Compression ratio: 10.01:1 (58cc heads), 9.39:1 (64cc heads), 9.02:1 (68cc heads), 8.68:1 (72cc heads), 8.37:1 (76cc heads),
* Head type: Flattop with 4 valve reliefs
* Oversize: .040 in.
* Ring size: 5/64 in. top ring, 5/64 in. second ring, 3/16 in. oil control ring
* Weight: 595 grams
I had gotten sold wrong heads and it was take these or nothing and I wanted the smaller chambers:
Here are the heads drilled for my manifold and what I thought I had gotten. One takes what one can get at this point:
http://www.smedingperformance.com/en...uck_engine.htm
STL-H345NP40
Specifications:
* Bore: 4.040 in.
* Stroke: 3.480 in.
* Weight: 595 grams
evilstuie
Jan 9, 2020 08:29 PM
NinjaNife
Aug 23, 2015 11:49 AM
2236720167, 2236720167t, 67, bolt, cc, center, chevy, compression, elongate, heads, holes, intake, manifold, ratio, tbi
