edelbrock tbi manifold
Car: 2002 Z28
ill be running my car next week at the track, then during my spring break i plan on putting on my edelbrock performer tbi. So by the end of march i should have before and after times.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
You probably won't feel that much of a difference from just swapping the intake manifold, but you should do it anyways because its a must have mod if your going to keep your TBI motor and other upgrades are to follow.
And that aluminum manifuld looks good in the engine compartment.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I just felt a little more pull on my top end but not much more. it will help me out now that I have the new cam but for a stock car with the stock heads and cam the stock intakle will suffice. It is a great mod as far as "pure bolt ons" go and didn't require anything special to install. My only beef is that it comes with the small stock size inlet bores. However, I have recently remedied that situation and bored mine to 2" so that I can use a larger TBI unit down the road.
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
