what do you think??
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
what do you think??
what do you guys think of this combo
Here is what is going in tommorrow what do you think of the motor?? Need some info on what you think of the cam since the cam place change the cam from what we told them. thanks
350 bored .020 over 10.22CR , ported 441 heads, Large valves 2.02/1.60, Weiland 7547 intake, Crane Pro Magnuim Roller Rockers, 454 TBI, headers from dynomax, crane ingnition, and i'm probubaly getting tbichips to make me a chip. 80lb injectors, w/ vafpr.
Bullet racing cam based on the Lunati 501A3LUN
duration @ .050
int. 218/exh 218
int .510/exh .510 lift
112 sep, 106 c/l
3 btc 35abc
47 bbc -9atc
duration @ .050
int. 218/exh 218
112 sep, 106 c/l
3 btc 35abc
47 bbc -9atc
Car: 1992 Camaro RS
anyone want to make a comment?? the motor should be running tonight i'll let you know how it works out.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i would give it more cam. 218 isn't alot of duracton for a 350.
i wouldn't go mail order on the chip either, learn to tune it yourself, or you will never be happy with the tune on a engine that far from stock.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
For the street that cam wouldnt be bad. Probably give a powerband up to around 5k and change. If your not satisfied with it, you can always put another one in. With that engine, though, a warmed over stock cal. isnt going to cut it. Youll want to go and pretty much redo everything. The stock timing curve especially. It has lots of peaks and vallies in it which will cause the engine to bog down in some spots and have detonation in other spots.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by brodyscamaro
Cam is pretty small....
IMO - at least something in the 230 range...
