fuel pump??
Old Feb 16, 2004 | 02:29 PM
DEATH88305's Avatar
Car: 1988 IROC CAMARO
Engine: 5.0 F.I.
Transmission: 700 R 4
fuel pump??
I HAVE A LIL WHINING SOUND FROM THE PASSENGER REAR OF MY CAR FROM WHEN IT SITS, I CAN GO OUT TO THE CAR 2-3 HOURS LATER AND HEAR IT, IM THINKING ITS MY FUEL PUMP, IT SOUNDS THE SAME, BUT WHY WOULD IT RUN ON ITS OWN AT ANY TIME FOR LONG PERIODS, TO MY BATTERY EVEN WAS RAN DOWN ONE TIME BECAUSE I DIDDNT DRIVE IT FOR OVER A DAY... IM THINKING I NEED A NEW RELAY, HELP!!! ANY INPUT APPRECIATED
THANKS.javascript:smilie('')
Old Feb 16, 2004 | 06:16 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
Have you looked at your wireing harness lately?
That would be the pump you're hearing, but it should go off with the switch.....relay or no relay!
Old Feb 17, 2004 | 12:03 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If the relay contacts are melted together in the on position it wont matter where any of the switchs are positioned. The pump could still run on because of a melted relay. Pull the relay out and measure the resistance of the high current side. If it low you have a bad realy. IF its high you have a problem somewhere else like bad switchs or grounded wire somewhere.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
