Need a fuel pump part number
Old Feb 20, 2004 | 08:56 PM
Tajini's Avatar
My TBI is not getting enough fuel pressure. When I start it up it will run for about 10secs. and die (no codes). And when I check the fuel pressure it's about 8-9psi at idle and drops even more under load. Tried a new one but samething. I think factory says it should be 9-15 psi. Anyway was wondering if someone had a part number for a framerail pump in the 20psi range? I figure the regulator will cut it back to where it should be.
thanks
David
Old Feb 20, 2004 | 09:06 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Need a fuel pump part number
thanks
David
The regulator will keep the pressure right where it needs to be. What year car do you have. You need in intank pump.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
