Good intake to use with lt1 cam?
Car: 1991 camaro RS
Engine: 305 Carb
i am getting ready to do a cam/intake swap. I am going with a LT1 cam and im gonna use a edelbrock intake, but i dont know which one to buy, which one will be the best for my setup?, oh and its a lo3 305 TBI
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Good intake to use with lt1 cam?
Car: 1991 camaro RS
Engine: 305 Carb
i tried a search but didnt really have any luck. yes i am looking for a direct bolt on, will buy an adapter plate but is there anyway around that? And about the EGR stuff, this is all new to me, what exactly is the EGR and do i really need it? If not then i will toss it. Thanks
Car: '90 RS
Engine: 377 LSX
I just bought the edelbrock tbi intake last night. I think it's a great intake for our cars. It's got egr, is a direct bolt on, has the same plenum depth as the rpm manifolds, the bores are centered, and is basically perfect in every way if you are using the stock 1 11/16 throttle body. The only downside, as shifty stated, is that if your combo needs the bigger 2 inch tbi then you will have to bore it out, but that is a pretty minor thing IMO.
Car: '90 RS
Engine: 377 LSX
Forgot to mention that it is a great intake for novice intake installers. You literally have to modify nothing. The only thing I can think of is bending the fuel lines a bit.
