Functional Cowl Hood
Old Mar 25, 2004 | 10:11 PM
cas0484's Avatar
Car: 1994 25th Anniversary Trans Am
Engine: Lt1
Transmission: A4
If this has been explained, please point me in the right direction. But I searched and have yet to find what I'm looking for. I currently have a Harwood 3 inch cowl hood. I have the open element and I would like to make it functional. What exactly do I have to do? Does anyone have any pictures or could explain what I need and exactly what to do? Also, the underside of my hood doesn't have the cutout for the air cleaner. It just rises up and leaves alot of room under the hood. Any input would be greatly appreciated. Thanks.
Old Mar 25, 2004 | 10:28 PM
steve8586iroc's Avatar
Sounds like you have a few differnt ways you can go.
I'll give the ones I can think of.
1. Build an air filter assembly that picks it's air up from the rear (simular to a nascar setup).
2. Take a flat peice of aluminum and attach it to the bottom of the hood then cut around hole in it for the open element to go up through, and don't forget to seal it off around the bottom of the air filter assembly.
3. Take a flat peice of aluminum and make a filter base that will also seal the bottom side of the cowl area or raised area then use your filter and lid to hold it in place. You may also need to brace the corners of the flat alum. to keep it sealed good.
Anyway those are my ideas, I'm sure someone else will add to this soon.
Steve
Old Mar 25, 2004 | 11:08 PM
25THRSS's Avatar
it's still functional the way it is
Old Mar 25, 2004 | 11:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Agreed. You are getting air that comes off of your windshield. You still get some residual air that is around your engine bay but not that much. You could fab up a device like steve described but you have an okay set-up as is.
Old Mar 26, 2004 | 03:11 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
take a look at pictures from first-gen camaros. Some of them came stock with functional cowl-induction (sealed up against the hood) and the way they are set up would be a great way for you to do it!
Bruce (90RS305)
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
loud91rs
Oct 5, 2015 10:05 PM
