Someone please help with tach install on TBI
Old Jul 30, 2004 | 04:38 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I have had it with my crazy tach, so I purchased a new Autogage pedistal mount tach. Any of you TBI guys that have installed a similar aftermarket tach please tell me how. I have read the instructions, but my wiring is kind of a mess so I need help!
Old Jul 30, 2004 | 06:20 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
it really doesnt matter wht tach u use. if u hve a decent repair manual look for the wiring diagrams. on min eat least itsa green tach lead. jus wire it into tht and keep it away from the spark plug wires cuz thtll make the damn thing jump...a lot..
Old Aug 4, 2004 | 04:22 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
just wire to a 12v source, and splice into the white wire on the grey terminal on your duel connector coil, and of course your ground
Old Aug 5, 2004 | 07:51 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
For your tach (or any tach for that matter), this is where you hook up the wires:
12V ignition- Look at the fuse box and use the IGNITION spot. There is no fuse there, FYI.
12V lighting- Use the INST LPS fuse wire (it should be gray)
Tach signal- Use the white wire going from the coil to the wiring harness (not the white wire going from the coil to the distributor)
Ground- Of course, just use a good engine ground
If you still don't understand what to do, just post and I'll elaborate on what to do. Good luck!
evilstuie
Jan 9, 2020 08:29 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
