tune up questions
Car: 1992 25th Anniversary Camaro
Transmission: Auto :(
tune up questions
How much is a tune up typically on a 305 TBI? I need one pretty bad and i'm wondering how much your's ran for and how much it helped your car. Mine is gettin clsoe to 126K miles and it spits and sputters some, howm uch did it wake your ride up when you gave it a tune up?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Tune up prices will very depending on where you go to. Dealers can be upwards of $600 while a local shop will be much much less. If you have basic hand tools and an afternoon you can accomplish all of this on your won. It is pretty straight forward and you will learn a lot about your car in the meantime.
Esential things to so durning a tune up
Change plugs, wires, cap, rotor, 02 sensor, PCV, and air cleaner.
Others things to check and or to do if they have never been done before in the life of the car are to, check the timing, flush the coolant, change the rear end fluid and tranny fluid (auto cars only).
would i be ok with jsut a new cap, plugs, wires, and just cleaned out the filter? becuase ive looked at it, and it looks pretty decent, is a fram worth cleaning? or should i consider getting a K&N?
Car: '90 RS
Engine: 377 LSX
