which sensor???
Old Aug 27, 2004 | 07:18 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
which sensor???
My car is running like $#*! and i think it is a bad sensor. The car starts up fine and when it is in park i can rev it up all the way and it feels realy strong. However when i put it into drive and give it some gas it stutters, knda like its not getting enough fuel or i have a couple spark plug wires switched around. But when it is in drive and i hold the brake i can smoke the tires still. Ive checked all the spark plug wires to make sure they were in the right order and i checked my timing and everything is perfect, so im guessing it is a sensor. If this sounds like a sensor to anyone please let me know which one it might be and where it is located. Thanks
Old Aug 27, 2004 | 08:03 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: which sensor???
Is the Check engine light on start by checking for trouble codes. A chiltons will explain how to do this.
Could be a weak fuel pump...clogged fuel filter you need to check fuel pressure to be sure. Hope its not, you´re in for a fun weekend if you need to replace the fuel pump.
Old Aug 28, 2004 | 10:06 AM
Car: 94 25th TA
Engine: 355LT1
only when i give it gas the SES light flickers on and off. And i used the paper clip to check for codes and nothing comes up. I know the fuel pump is getting weak and probally should be replaced soon, but i really dont feel like doing that. i was really hoping it might be a sensor.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
