Fuel pump fuse
Old Nov 25, 2004 | 11:51 AM
momybear's Avatar
Fuel pump fuse
could someone please tell me where the fuel pump fuse is Please..fuel pump is new ...car won't start ..think it's the fues...anyone that can help:-(
Old Nov 25, 2004 | 12:01 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Welcome aboard!
There is a fuse that protects the pumps circuits located on the fuse box itself (there's a pull down panel located down under the dash).
However, up front, there is a fuel pump relay fuse which protects the fuel pump relay. That is known to blow out, causing a no-start condition in which the pump does not prime nor start.
When you turn the key to the on position, not starting it, do you hear the pump prime for 2 seconds? If yes, skip this next step, if not, give this a try.
If you have a Camaro, look under the hood, by the radiator overflow and the battery. You will see a little inline 20a fuse in a weatherpack protector. Look at that and make sure it isn't blown. If you have a Firebird, look on the vertical radiator support, battery side. Same 20a weatherpack fuse holder. If that fuse goes out, it cuts power supply to the fuel pump relay, which in turn, cuts all power to the pump, priming or normal running conditions.
Old Nov 25, 2004 | 12:14 PM
momybear's Avatar
can't find
car is a 92 rs covertable...can't see the fuse up front and in the panel there is no place marked f pump for fuse..could there be another name used or letter? this is so frustrating..this car has been a kettle of worms
Old Nov 25, 2004 | 12:26 PM
momybear's Avatar
woo hoo
figured it out... loose wire whew...ty for your help...happy Thanksgiving...momybear
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
