Messed up
Old Jan 2, 2005 | 11:18 AM
tb8125's Avatar
Messed up
did a full tune up yesterday and i think i put the wires on the cap ssa drawkcab can someone please help what wires where thanks in advance 88 305
Old Jan 2, 2005 | 01:29 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
best way to do it, is to turn the engine over to TDC, then pull the cap, and look at where the rotor is pointing, that will be where the #1 connects, then follow around clockwise in the firing order.
Old Jan 2, 2005 | 11:47 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Keep in mind that the engine has both a #1 and #6 TDC. If the rotor is pointing at the firewall when the engine is at TDC, rotate the motor around once more.
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
mrbird
Oct 20, 2015 03:43 AM
