where can i find a coil to ignition module coonector
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
as the caption says,does any body know where i can find one?i`ve tried the dealer and they told me it was discontinued.the junk yards around my place suck so if anybody can point me in the right direction i`d greatly appreciate it.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may have to do some searching but you should be able to get it from www.gmpartsdirect.com
how could i find out the part number for it?
That little 2-wire jobbie with the coil connector on one end and the 2-wire weatherpack connector on the other? You must have some REALLY pathetic junkyards in your area. That connector is the same on almost every GM car that uses a remote coil type HEI distributor. V8s, V6s, I-4s. Just a matter of the length of the wires from the coil to the distributor.
dude all the cars in all the junkyards in my town are nothing but skeletal remains.about the only thing you can get here are all steel parts.
