Apr 23, 2005 | 09:38 PM
For an intake on the 305 TBI engine, is it the same bolt pattern as the older style heads?
What I mean is would this intake bolt up to a older block?
Reply 0
Apr 24, 2005 | 07:19 AM
It will bolt up to the CBVC heads only. untill the LT1 that is.
Reply 0
Apr 24, 2005 | 09:03 AM
Doe that mean center bolt valve cover heads?
What is the difference?
Is it that the bolts are at a different angle?
Or is the mounting surface a different angle?
Reply 0
Apr 24, 2005 | 10:38 AM
The four center bolt hols are at a different angle. You can make any post '87 intake work on '86 or earlier heads but you will need to wallow and modify those 4 center holes. There are so mnay intake you can you it is just easier to buy one that fits to your heads.
Reply 0
Apr 24, 2005 | 04:15 PM
It would probably be easier to buy an aftermarket intake... maybe I'll see one in the classified section.
If anyone reads this and has one for sale, send me an email:
lawrence_1md@yahoo.com
Reply 0
Subscribe
