Help wiring a 454 TBI TPS sensor
Old Apr 25, 2005 | 11:58 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Need help regarding wiring for the TPS. Colors for the TPS wires on the 454 TBI sensor does not match with the stock TPS. Any help would be appreciated.
454 TBI
A= Black
B= Blue
C= Gray
305 stock TBI
A=Gray
B= Black
C= Blue
Old Apr 26, 2005 | 04:28 AM
7Point4's Avatar
Car: 1990 Chevy 454SS
Engine: 454
Transmission: TH400
TPS
According to the print i have for my 1990 454SS..
The center wire is the input to the ecm, dk blue-wht.
'top' wire is sense return , blk
'bottom' wire is ref voltage, gry
I would say hook it up, making sure the center wire is the return to the ecm, and turn the key on, do not start it, and watch the reported TPS with scanner, or put a meter on it. voltage should go up, to the ecm, with more throttle. if it's backwards, swap the black and gray wires (the outside wires).
Old Apr 28, 2005 | 04:34 PM
86z/92rs's Avatar
Thanks for the responce. To tell you the truth, I don't even know what year this 454 TBI came from.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
fonzie85
Aug 13, 2015 11:50 AM
92camaroJoe
Aug 13, 2015 06:07 AM
