700r4-->T-5...What Bin did you use?
Car: White KSwisses
Engine: 5.3L Gen III
For those of you who swapped from an auto to a manual, what bin or mask did you use?
BTW...going from 305 TBI 700r4 to manual.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I beleive that AXKW is the 92 5speed bin, my 90 5speed came stock with APTY. Pretty much any 5speed bin should work fine.
Car: check
Engine: check
Transmission: check
cali92RS, your in California? If so then for the yearly tailpipe testing I would recommend the AXKU bin. It is the CAL emissions calibration. For general use the AXKW is a better calibration. Looking a the differences I'd say better driveability, power, and mileage with the FED calibation (AXKW). However, lower emissions with the CAL calibration.
RBob.
RBob.
Car: White KSwisses
RBob.
RBob.
However, this is only a temporary solution.
Shortly, Im going to be swapping in a super rammed 350. Im only going to use this bin untill the swap is complete.
Car: check
Engine: check
Transmission: check
Originally posted by cali92RS
Yup california.
Yup california.
RBob.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
