cooling problems
Car: 91 camaro rs
Engine: tbi 305
Transmission: 5 speed
cooling problems
for some reason my fan only comes on if i turn the ac on , i'm pretty sure this isn't normal and i barely ever use the ac because it doesn't blow cool air wich is a whole other ordeal. during regular driving the temp stays pretty low but stop and go it tends to get warm. is this a normal problem and relatively easy to fix ?
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 700r4??
very common problem... i had the same. i found out the easiest way to fix this is to buy an aftermarket temperature control relay. i got mine at pepboys for about 30 and youll need to go buy a fuse...but for me that fixed it...before that i replaced the fan relay, coolant temp sensor, engine temp sensor, radiator,and none of that fixed it but the aftermarket relay did.
Car: 1991 Chevy Camaro
Engine: 305 TBI
Re: cooling problems
This is what it looks like:
You have some options on replacing it, if the wiring turns out good. You can get a stock replacement fan switch at any auto parts store, but the factory switches turn the fan on at 238*, which is practically boiling. Both Hypertech and Jet make aftermarket lower temp. fan switches through places like Summit Racing or Jegs for about $40, but you can get the same thing for $13 here, part number 609-106: http://www.madvet.com/shop?frame=1.138.944
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
