TBI fuel line limit
Old Jun 16, 2005 | 12:53 PM
DanS's Avatar
TBI fuel line limit
How much power will the stock tbi fuel lines support?
I'm considering a LS1 swap. Will the TBI lines provide enough fuel?
Old Jun 16, 2005 | 01:50 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I put 300hp/440tq to the rear wheels on nitrous, it is all going thru the stock hardlines on the chassis, to -6AN briaded from the chassis lines to the TB and noids.
Old Jun 16, 2005 | 06:09 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Dewey what kind of times are you running on nitrous and did you have any additional tuning needs to run the nitrous?
Old Jun 16, 2005 | 10:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Those lines will be more then enough to feed a modest LS1. People have fed more power at lower fuel pressures so I would imagine youd be fine.
Old Jun 17, 2005 | 06:47 AM
DanS's Avatar
Thanks for the info guys. In a couple years, I would like to add aftermarket heads & cam to the LS1. Will the fuel lines still be enough?
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
