Fuel backfiring out TBI
Old Jul 9, 2005 | 03:33 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
So I did a swap to the LT1 cam and am trying to just get it to start, I have the stock chip in right now but will burn one soon. I hooked everything up and when I try to start it, it will backfire fuel out of the TBI. Did I maybe drop the distributor in at the wrong spot? It seemed like there were only 2 spots it would seat fully at on the cam, because I forgot to mark the location when I pulled it Any suggestions guys?
Because it's backfiring out the TBI, would that mean its too advanced, or too retarded? Which way would I turn it to solve that and just get it close?
Which one is my ESC connecter, the one right next to the blow, 4 wires in a straight weatherpack? Anyone have a picture?
Old Jul 9, 2005 | 04:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you may be 180* out on the dizzy. Get the motor to TDC on the compression strock, then drop your dizzy in. When the rotor is pointing, will be where you connect the #1 plug wire.
Old Jul 9, 2005 | 04:55 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
How can i find which one is TDC compression and which is TDC exhuast?
Old Jul 9, 2005 | 05:24 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Well, once i drop it in with #1 being at TDC, its either going to be #1 firing or #6 firing, right? so if its still giving me trouble, instead of connecting to what i thought #1 was, i could just move them so where i had the #6 wire is where i put the #1 wire, couldnt i?
Old Jul 9, 2005 | 06:15 PM
Dewey316's Avatar
Car: 1990 Camaro RS
yes, move the #1 wire to where you currently have #6, then move the rest of the wires to the proper place, following the firing order.
Old Jul 9, 2005 | 06:35 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Had the distributor 180* off, thanks for the help.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
