Need advice on Holley inline pump.
Old Jul 18, 2005 | 12:03 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hi I bought holley inline pump. The RED version. Its inline pump that pulls 7psi, and 97gph. I was wondering what would be the best way to install this baby.
Also, right now I have a TBI 305 with worked heads, headers, tuned prom etc. Would it be a problem to use this pump on the TBI. I am fixing a 350 lo5 as well thats why I bought the pump. ANyways, can you tell me what the best way is to put this pump in and where. Thanks sooo much. You guys always help me out when people start giving me quotes.
Heres the pic.
Old Jul 18, 2005 | 12:19 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id probably stick it as close to the tank as possible and run a 3-way regulator/use the stock regulator so you dont have vapor locking issues. Also, whats the range of pressures that the pump can operate over? TBI could need anywhere from 10-35 psi, depending on what your fuel needs are.
Old Jul 18, 2005 | 12:21 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Just looked, 7 psi is the max operating pressure. Youll need a stronger pump.
Old Jul 18, 2005 | 02:27 AM
Crap! How about a TPI pump for the 350. Or would the stock one work just fine!?!? Stock TBI pump.
Old Jul 18, 2005 | 07:26 AM
Car: 88 Camaro SC
Engine: SFI'd 350
TPI pump would work well as would, I believe, an LT1 pump if you prefer to use A/C Delco rather then Walbro.
cowansauto
Apr 3, 2025 12:51 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
codeysabatini
Nov 10, 2015 04:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
