cylinder head
Old Aug 23, 2005 | 07:46 PM
irocbadboy's Avatar
Car: camaro and gmc sierra
Engine: 5.0 l t.p.i,and 4.3 vortec
Transmission: manuel(iroc)automatic(other)
Axle/Gears: 3.45 bw
cylinder head
14102191 and 14102193 this head with full porting,is it as good as this head 14101083??thanks
Old Aug 23, 2005 | 08:50 PM
SchwarzCamaroRS's Avatar
the 193 cast is a TBI cast with swirl ports IIRC, the 083 is a TPI cast that flows much better. A ported 083 will do much better than the 193
Old Aug 23, 2005 | 09:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Do a search for user Fast355 and his post on "garage ported 193's". He has flow numbers for various swirl port heads and you will find that when ported they aren't that bad. They flow better on the exhaust side than the 083's but not as well as the on intake side. However, the flow advantage on the exhaust side is the lessor of the two evils. When fully ported the TPI heads will come out on top. However, in budget situations the 193's can support a solid amount of power.
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
