eddy tbi intake,a quick question
Old Sep 11, 2005 | 06:29 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
the question i have is exactly how much more does the eddy tbi intake flow more than stock?can i have the stock intake extrude honed to flow just as much?THe reason i ask is just to know if it is worth spending the 229 on the eddy when i can get my stock one done for almost nothing.any thoughts anyone?
Old Sep 11, 2005 | 06:58 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
well the edelbrock isnt much higher than stock at all so i know the runners cant be too much larger and they are both alluminum i belive, and the same bore size too...id say the only difference is restriction in the ports them selves if u can take a mold of the inside of your ports ud know where u needed to improve.
Old Sep 12, 2005 | 06:40 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Most people just go with a carb intake and an adapter, cheaper, and performs better.
Old Sep 12, 2005 | 11:59 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can port the upper plenum section of the stock intake but I am not sure about the runners. I believe the water cross overs are failry close to the runner walls. I would use a carb intake and an adapter plate and or get the edelbrock one for a more "OEM" fit.
Old Sep 13, 2005 | 07:01 PM
ok then if i was going to go with a carb intake what is the best adapter to use? i keep hearing if it`s to far back it causes problems or the same if too far forward.any thoughts?
Old Sep 13, 2005 | 10:43 PM
NEEDforSPEED's Avatar
i made my own
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
