testing ignition coil
Old Sep 28, 2005 | 10:32 PM
bwidner1's Avatar
Car: 1992 camaro rs
Engine: 305 tbi
Looked around on the site and could not find it, but I suspect my ignition coil is bad I have tried new cap rotor wires p/u coil but the injectors wont spray fuel is getting all the way into the injector pod but passing right through, I will also be checking the vats system bypass tommorrow, I also hear the fuel pump kick on
Old Sep 30, 2005 | 11:45 PM
bwidner1's Avatar
Car: 1992 camaro rs
Engine: 305 tbi
changed the coil and still nothing the car is getting spark but something is telling the injectors not to fire, tried new pressure regulator and injectors
Old Oct 2, 2005 | 04:45 PM
92ss wagon's Avatar
Car: Caprice wagon
Engine: 5.7TBI
I just went through a simailar thing. Car would idle fine, give it alittle gas and it would die. It all started after I changed the cap and rotor! I changed the ignition module, same problem. I ended up dropping a new distributor in it and it fixed everything. My point also is when I went to rev it before it died, I noticed it kicked the fuel off also. Best of luck.
DJ
Old Oct 3, 2005 | 12:36 AM
bwidner1's Avatar
Car: 1992 camaro rs
Engine: 305 tbi
were you getting spark b/c I just changed the pu coil and it did not help
Old Oct 3, 2005 | 06:02 AM
92ss wagon's Avatar
Car: Caprice wagon
Engine: 5.7TBI
Yes I was getting spark.Also, most parts store can check your ignition coil to see if it's bad.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
