Sputter, bog, stall at startup
Old Oct 6, 2005 | 11:02 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
When I start the car I have to rev it a tiny bit to keep it running, just a tap after crank or it stalls. Any ideas of what this problem might be? I'm about to do valve seals because it burns oil at start up, think the oil may be the problem?
Old Oct 8, 2005 | 11:33 AM
jimp2001's Avatar
Engine: LO3 305 TBI
anyone?
Old Oct 16, 2005 | 10:25 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
hey i also have the same problem so your not alone lol i have done a complete tune up with ALL fluids even the rear end, 02 sensor, iac motor. any body have any thoughts?
Old Oct 16, 2005 | 10:52 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
have you changed your fuel filter? i`d say get a fuel pressure gauge and check it.it could be a few things.
Old Oct 17, 2005 | 08:12 AM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
mine was doing that then i got to where it would die at startup and not start for awhile...i changed the filter and no help then i just thought to change the coil cause i had an msd coil laying around i hadnt put on yet and it fixed the problem.
john
RedLeader289
May 28, 2019 01:47 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
