Opinion on parts combo.
Old Nov 6, 2005 | 02:24 PM
BadDog's Avatar
Goal: Mild engine with good low-midrange torque that still pulls decent to 5-5.5k and gets decent mileage. Vehicle is a K5 at about 5500 lbs, 35" tires, 4.56 gears, and 700r4. Primary use off-road so needs solid and smooth/predictable low rpm power and quick response.
Stock breather housing with large cold air snorkel.
46mm TB with unshrouded injectors.
1/4" injector spacer.
Stock small block injectors.
14-16 psi FPR
AirAid TB spacer.
Crane compu cam 2030 (Summit CRN-104221)
Roller lifters and roller tip rockers.
SR Torquer heads decked 0.020 and mildly cleaned up.
Stock ZZ4 short block. (~9:1 compression).
Stock emissions with 2.5" single exhaust.
40 series FlowMaster muffler.
I don't have much faith in the TB spacer, but the PO installed it and I see no reason to take it off.
I'm ordering stuff today to burn my own PROM, but still got lots of research to do.
Should I go vacume referenced?
I despise headers, so I'll just deal with that limit. Noise, heat, leaks, interference, ever set I ever had any experience with was nothing but trouble. And switching to something like ram horns is not an option due to emissions testing.
Opinions in general?
LT1Formula
20
Nov 14, 2015 12:02 AM
Thornburg
Aug 25, 2015 01:46 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
