1.6 Rocker arms
Old Dec 2, 2005 | 08:52 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
1.6 Rocker arms
I found a cheap, but decent looking pair of rocker arms on summit's site. They are part number PRO-66915 . Could someone please look at them and tell me if they will work? There is a whole bunch of crazy technical stuff that I dont know what the answer is to. Thank you so much guys.
Old Dec 3, 2005 | 08:57 AM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
I posted this exact question a little while back, I was told they were junk and to stay away from that brand. You may want to try these... http://www.sdpc2000.com/catalog/1956...Arms-87-UP.htm
Don't both reading the description its for the wrong part, but the specs on it are still good, and they do come with the pivot ball and nut.
Old Dec 3, 2005 | 01:14 PM
Engine: LB9, LB9
So the ones you just linked wont fit?
Old Dec 3, 2005 | 01:44 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
the ones I linked will fit, its just that if you look at the site it shows the wrong description for that part even though it is the right part. The one I linked is stamped 1.6 rockers with the nut and pivot ball. Its the one you need.
Old Dec 3, 2005 | 01:52 PM
Engine: LB9, LB9
Ok thank you man, great help.
Old Dec 3, 2005 | 01:54 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
I did a good bit of research on 1.6 rockers and decided I was going with a cam instead so I'm glad someone could get some use out of it.
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
