fuel spray out of the TB?
Old Dec 4, 2005 | 06:00 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I've been having trouble with my LO3 just resently. When I start it up it will idle really rough and when I open the throttle fuel will spray back out of the passenger side tbi bore. It isn't a constant spray. It seems as if one of the intake valves is staying open on the compression stroke. Does anyone know what TB bores feed what cylinders? That info would help me narrow my search to a mechanical problem in a few cylinders.
Old Dec 4, 2005 | 06:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Each bore feeds both banks with a dual plane. I dont recall off the top of my head which feed which but youd probably have to follow them by eye. The best solution probably would be to do a compression check on all cylinders to make sure all is well. It could also be a misfire, or even a blown head gasket.
Old Dec 4, 2005 | 09:55 PM
iggy1991's Avatar
Well there is NO compression in the number 1 cylinder on the passenger side. When I loosened the rocker arm nuts to close the valves and reran the test, the compression jumped right up. I'm gonna try to shim the springs and see what happens.
Old Dec 4, 2005 | 10:23 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Sounds like there is lots of gunk on the valve stem, or the valve stem is bent.
Old Dec 5, 2005 | 10:19 PM
iggy1991's Avatar
Ended up being a broken valve spring. Guess I have to call comp cams in the morning and see if its covered under warranty.
Old Dec 5, 2005 | 11:30 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Was that one of comps springs? How much lift where you running?
Old Dec 8, 2005 | 10:48 PM
iggy1991's Avatar
Part Number 08-500-8
Engine Chevrolet
305ci-350ci
8cyl.
Grind Number CS XR258HR-12
Description
Intake/Exhaust
Valve Adjustment 0/0
Gross Valve Lift 0.48/0.488
Duration 258/264
Lobe Separation 112
Its the highest lift cam I could get with stock LO3 heads. Its pretty good for what it is.
92camaroJoe
Jul 29, 2023 07:57 PM
destroyerwes
Aug 26, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
killer777
Aug 8, 2015 02:47 PM
