tbi and tpi pics??
Old Dec 16, 2005 | 01:19 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
tbi and tpi pics??
i would like to see engien pics of early 80's and up to 92 iroc..im getting an iroc camaro tomorrow but i still have to visualy see and inspect it,.,.it does have a v8 so i would like to see all the possible engins it could have im guessing it will be a 305
Old Dec 16, 2005 | 02:02 AM
iroc22's Avatar
First off, IROCs were only made from 85-90.
Second, easiest way to tell what engine was installed is to check the 8th digit of the VIN. See what it is, then we can tell you what kind of engine is in there. The number/letter it could be are: H, E, F, 8
Old Dec 16, 2005 | 06:07 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
wow this post made no sense after reading it so just ignore it.
Old Dec 16, 2005 | 10:12 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Checking the engine digit is a good place to start but I would also look at the engine itself in case the previous owner swapped motors. If it has a large round air cleaner assembly on top than it is a carb motor or TBI. If the motor is TPI will look like a big metal spider is attached to the top of it. Ha. You can get block casting numbers (behind driver side valve cover) to determine its origonal displacement.
Old Dec 21, 2005 | 09:13 PM
iroc22's Avatar
Originally posted by flaming-ford
H, E, F, 8
The 3 and f are tbi and tpi, h i'm guessing probably carb'd and 8 no idea (splitfire maybe). J/w because, i'm only familiar with the e and f.
H is LG4 (carbed 305) and 8 is L98 (350 TPI)
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
junkcltr
Aug 2, 2019 11:12 PM
Sanjay
Aug 12, 2015 03:41 PM
