2-piece Power/Amp series pulleys
Old Jan 31, 2006 | 08:44 AM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
After a lot of dispute I figure they're cheap enough ($50 for the set) I might as well get them anyways. The only question I have is will I need a bigger belt or a smaller one? About how much bigger/smaller? Don't know if it matters but I've alread ditched the AIR pump.
I called March to see which PN fit they gave two one was for the 3-piece aluminum (didn't want this set so didn't keep the PN) and another for 2-piece steel which is 4405 or MCH-4405 if you're looking on summit.
Old Feb 11, 2006 | 05:19 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
Well they're on there now, wasn't much of a SOTP difference but it does seem to revv a little easier. There was absolutely no drop in voltage so thats a plus. I'm probably going to the track Wednesday so we'll see if I'm quicker.
Old Feb 15, 2006 | 11:18 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
Nothing has gone wrong yet, temp is the same as it always has been and so is the voltage reading. I went to the track tonight and ran a 16.81 down from bone stock of 17.55. Nothing spectacular but I'm getting there.
Old Feb 16, 2006 | 12:58 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
damn thats actually quite the increase.maybe these might just be worth it.
Old Feb 16, 2006 | 12:17 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
How much of that was weather, it was 70 vs 85 last time I ran?
Old Feb 16, 2006 | 04:04 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Im glad to hear that they worked out for you...considering so many people think its not worth it. Im looking to get the Power and Amp Series 2 piece set in the spring. How much did the belt run you?
Old Feb 16, 2006 | 04:06 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
It was just a cheap dayco, most people swear by gatorback, I really think a belt is a belt though. It was about $25
Hotrodboba400
Dec 10, 2019 07:07 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
