flames crawling up my windsheild
Old Jan 31, 2006 | 07:34 PM
91WhiteCamaro's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
ok, i was driving home today from a friends house, and when i pulled out to my street i gunned it. well i already have a bad hesitation (recently i was told it was caused by a bad injector of mine) and after the horrible bog i witnessed flames come out the rear of my hood to about a quarter way up my windshield. why would my TBI backfire so horribly?
Old Jan 31, 2006 | 08:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is your base timing set at? If your timing is way off the map you can have a nasty backfire through the TBI.
Old Feb 1, 2006 | 04:06 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Not to say your wrong, matter in fact i'm sure youre right but, how so would that cause it?
These computers have knock sensors which if pinging is detected they automatically retard timing so there won't be any more damage to the motor (at least that's how i thought it would work). You'd have to be pretty far advanced to have it do that and your motor would most likely be pinging with that much wouldn't it?
Old Feb 1, 2006 | 08:17 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Its actually the other way around. The timing is too far retarded which causes the backfire (no detonation). Also, you can have audible knock even with the sensor present. It doesn't correct knock if you run your engine out of its range.
Old Feb 1, 2006 | 02:34 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
well that helps i appreciate you clearing that.
db057
Apr 28, 2019 07:45 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
2012sergen11
Oct 13, 2015 07:38 PM
Hello, Michael
Sep 11, 2015 01:10 PM
buckshot63
Sep 10, 2015 09:15 AM
