91 Caprice Intake on my LO3?
Old Feb 6, 2006 | 07:35 PM
Dan89RS's Avatar
Car: 89 camaro rs, open k&n, 80 series, air delete
Engine: 305/5.0L tbi
im lookin for an intake for my 89 305 tbi. i found a cheap manifold off a 91 caprice cop car (9C1). i cant find anything that says if it will or wont fit on my engine, or if the tb is gonna fit.
basically, is this a direct fit?
Old Feb 6, 2006 | 09:03 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
That'd be the same intake manifold you have right now. I wouldn't do an intake as your first mod to the car, if in fact this is your first mod. What are your plans with the car?
Old Feb 7, 2006 | 07:32 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Well yes and no. I agree that an intake swap shouldn't be the first mod. Cold air intake is an easier/cheaper DIY swap, but the most bang-for-buck will always be the exhaust. I don't agree on the intake comment though -- it's not the same.
On the intake manifold itself, as far as TBI placement, attachment, and port locations to the heads -- is the same. IOW fit and function is the same on the Fcar as the Bcar.
BUT, the distributor "hole" is not the same. On the 91-93 B platform TBI cars (Caprice, Roadmaster, Custom Cruiser) the intake manifold had an oversize distributor hole that was also recessed slightly (IIRC). The distributor used on those cars had a shaft housing with a flange to exactly match the size and depth on the manifold, and as I understand it, the shaft on that distributor was also a different (smaller) length.
The purpose for using the one-off manifold was to allow removal/install of the distributor within the tight confines of the cowl overhang, so a special disttrib/intake was needed.
So you could use it on the Fcar but you would need the matching distributor to get it to bolt on and work properly.
Relevant threads:
https://www.thirdgen.org/techbb2/sho...aprice+distrib
Old Feb 7, 2006 | 01:15 PM
BronYrAur's Avatar
Engine: 305 TBI
Good info to know. I was more referring to it from a performance standpoint. The ports and everything are going to be the same so there would really be no reason to swap that manifold onto his car. I think exhaust and rear gears/posi should be the first mods. Kind of a cool idea though from GM with the oversize distrib hole, that's pretty cool.
Old Feb 7, 2006 | 03:22 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Ah the stuff we 91-96 B-body owners have to deal with all in the name of a 0.32-0.34 Cd.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
toronto formula
Sep 10, 2015 07:31 AM
Strick1
Sep 6, 2015 10:38 AM
