Mill my Vortecs??
Old Feb 10, 2006 | 01:08 AM
1991 RS 305's Avatar
Mill my Vortecs??
I'm hoping to get my vortec heads to the machine shop tomorrow. I'm having them milled and back cutting the valves. I've done searches on this and .030 seems to be the magical number to have shaved off. I thought it would be neat to be able to keep the heads CC stock and just run a thinner gasket. In all my searches it seems the best compression I'll get doing this will be like 9.2:1. This is ok, but I might as well kick her up to 10:1 since compression is free power. Is it agreed that this will be a safe ratio? Will .030" do the trick? I think for 10:1 I'll need about 56cc chambers? Any opinoins appreciated on the above info!! Second thing is the head gasket. Which ones are best. Since I'm milling the heads I'm assuming I don't need to go with an ultra thin gasket. Anyone know what thickness I'm shooting for?
Thanks for any input. Matt
Old Feb 10, 2006 | 01:21 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
For the gasket, you want the stock style which IIRC is .015" If you go with a thicker head gasket, you will mess up the qwench. If you go to a 56cc chamber, with a stock head gasket, you should be golden.
Old Feb 10, 2006 | 02:57 AM
Excellent!! Thanks for the quick reply!
I should also ask... With this much removal from the heads, will I have problems with the angle of the intake meeting the heads? Edelbrock performer RPM Vortec is the intake I have if it matters.
Thanks..
Old Feb 10, 2006 | 04:52 AM
DM91RS's Avatar
Car: 91 RS
Thanks..
The angles are one reason I left mine stock with no milling and used a GM composite head gasket .028" thick. Runs on 87 all the time also.
Sorry it doesn't answer your question though
DM
Old Feb 10, 2006 | 08:27 PM
So I was at the machine shop and the guy there wants to make sure we hit the compression I'm looking for without going too far. So I'm looking to find out what kind of pistons came in the LO3. Are they a dish, flattop? Id they are a dish or if they have valve reliefs, does anyone know the CC of the piston? Thanks!!!
Old Feb 11, 2006 | 08:44 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The intake you choose should seal. Board member Chuck! runs milled vortecs (.030 removed) and he runs the performer vortec carb intake with an adpater plate.
They have four vavle reliefs with a slight dish. I believe the switch to this style was in '87 when they reduced the CR on the 305 from 9.5:1 to 9.3:1.
Old Feb 12, 2006 | 02:56 PM
Thanks for all the above info. Not to be a pain, but do you think it's safe to mill my heads to 56cc. Should I play it safe and go to like 57cc? I am worried about detonation issues mainly. But at the same time compression is free power. I will burn premium of coarse. I have to call the machine shop in the morning ant tell them what cc's I want. Any more input is appreciated!!
Thanks, Matt
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
