it starts , but need to pump it
Old Mar 23, 2006 | 02:26 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
well again , let me start out with
when i got the car everything ran fine for about 1 month then i started going down hill
things i have done , most of all sensors changed with new ones , tune up , cap rotor plugs wires , water pump , timeing chain , alternator ,raidator(sp?) , time belts , and what ever the hell the part is them belts are hooked to (forgot what its called to tired to remember) new TBI unit 750 cfm , hoses , battery , and other smaller odds and ends
but after about a week of it starting like **** i did a few of the things listin above , now when the cars running its running fine you can give it gas and it goes you can rev it and it goes it just has the hardest time starting up which is a big problem
casue i crank it over about 2 times and it wont start and by the 3rd time my battery is dead and nothing in the car works , now i am thinking starter or fuel pump , the fuel pump the guy i bought it off of said it was only a year or less old and the starter 2 years , i am realy starting to give up on it casue i need a car that can at least start right (and say if my timing is off would that have any factors in this not starting right casue it dont shift right but the guy i had look at it says its fine and he is a good friend of mine but it still dont like to kick into 2nd)
does any one know were that shop in vermont was that looked at 3rd gens ? casue i know i can get it up there but i dont know if it could handle the drive back right away
Old Mar 23, 2006 | 02:48 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
and on a side note , we had probs with the VAc system (pos systme if ya ask me)
and my father thinks if theres something worng with the wiring could that casue this prob , i told him i dout it but eh at this point ya never know
i am replacing the fuel and starter next if i cant find out whats worng with it
Old Mar 23, 2006 | 07:56 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Did you get bigger injectors with your TB? If so that probably has alot to do with it. You may try swapping your stock TB back on and see if that fixes it. You don't need a 2" TB on a stock 305, and most of the time it causes problems without tuning.
Old Mar 23, 2006 | 11:38 AM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
well my old tbi broke when we were re drilling the holes for the new screws , i will try and get the injecyor numbers but this prob was happening before i even swaped it
Old Mar 23, 2006 | 11:11 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
any one else got some suggestions seeing i dont feel like finding them numbers =)
also doing fuel filter next week it did not wanna come off this day heh freaking things on there good put some good losing sprey on there
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
