Installation MSD 6AL
Old Apr 21, 2006 | 08:02 AM
Raul_Chile's Avatar
I want install a MSD Box 6al, but i don´t understand how.
MSD Box has wire (+) y (-) supply. Wire pick up(no used) and Wire Red Switched 12V+ with key ignition and ¿¿¿¿Wire White?????.
I need to buy special conectors?
I have 350TBI 1992 with 8-pin module HEI.
Where I can find diagrams at respect?
Regards from Chile
Old Apr 21, 2006 | 11:40 AM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
check out MSD pn 8876
Old Apr 21, 2006 | 03:44 PM
Raul_Chile's Avatar
nice the connector.
With It and Box 6AL the ECM keep timming Control as original?
thanks
Old Apr 22, 2006 | 10:25 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Originally Posted by Raul_Chile
nice the connector.
thanks
Yes. Timing is controlled by the ecm computer, not the 6AL.
S-D
Old Apr 22, 2006 | 10:56 PM
Raul_Chile's Avatar
S-D
Ok thanks.
Today installed MSD Coil 8226 and idle changed from 900rpm to 1100rpm. I will buy now wire, cap, rotor, plugs MSD.
Regards
Old Apr 23, 2006 | 12:36 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Babblefish or just a noob at English?
Entertaining, it is.
Old Apr 23, 2006 | 03:48 PM
Raul_Chile's Avatar
Newbie English. We have Here in Chile much equipment, Mining, electronic and each manual is in English. We have neccesary to know some.
Is very bad my English? I read without problem yours forums (But write ??)
Our WEB in Antofagasta City:
Team-Monster Website - Home
Regards
Old Apr 23, 2006 | 04:02 PM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
heres that sentence translated to proper english
"Is my english that bad? I can read your forums without any problems"
Old Apr 23, 2006 | 08:24 PM
Raul_Chile's Avatar
I want to buy splitfire, but in your WEB show me "Split-Fire TP2E" + photo, I see that plug with long neck and final ring. But my actual spark plugs are short neck and cone to seal.
Is correct model TP2E for 305TBI?
Raùl
Old Apr 26, 2006 | 08:47 AM
shuf's Avatar
Car: '89 Firebird Formula R.I.P.
I am also hooking up an MSD ignition. I wanted to replace my cap and rotor with a MSD one, but I am not sure what p/n to use. Any help?
Old Apr 27, 2006 | 04:30 PM
Car: 1991 RS
Regards
Your English is fine. Much better than my ability to write, speak or understand Chilean (sp?). I have just returned from Germany and am in a position to fully appreciate the fact that other countries at least take the time to learn our (US) language. He!!, I went to college for 11 years straight, obtained 6 degrees and never even took a foreign language class. However based on the influx of Mex-e-cans into the US and my recent trip to Germany, I wish I had.
Anywho,
SplitFire sparkplugs:
I have heard mixed reviews on these plugs. You may be better off buying standard tip spark plugs. If you insist on split fire, you may confirm part numbers on the Summit Racing site (www.summitracing.com). I have always run the standard type plug (single point) with very good results on a highly modified engine.
Shuf- You may refer to the Summit Racing Site also. Perhaps MSD part#MSD8406 will work? The search engine on Summit Racing usually proves pretty helpful in finding part numbers.
S-D
Old Apr 27, 2006 | 07:57 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
don't go with splitfire plugs beleive me i just did and ended up yanking them about 500 miles afterwards...... Definetly made my 305 run like complete crap. I replaced them with ac delco rapid fires and it runs like a top once again.
Old Apr 28, 2006 | 12:53 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
In case you don't have AC Delco's, go for other good simple reliability plugs, such as Champion or old school NKG, buy copper ones.
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
