TBI fuel regulator
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Yes more pressure is more pressure...stock tbi:turn screw clockwise ti increase pressure.....try a search and you will get a million hits
Car: check
Engine: check
Transmission: check
Shoot for 30 psi and put the 305 injectors back in. They flow 55#/hr (at about 11 psi) which is more then the 4.3l injectors flow. As a general guideline for an engine that goes to 6,000 RPM the BPC needs to be 90 or lower. Using async mode as you are helps with the duty cycle, but gets quirky at lower engine speeds.
RBob.
RBob.
ok, i got the pressure WAY up with the stock L03 injectors....way cool, world of difference, but you did spark my interest with the Asynch mode. Can i make that work with me on WOT to? I know it comes on on deceleration, i was looking for a way to make it come on full throttle, but i dunno
Car: check
Engine: check
Transmission: check
By setting these parameters as they are, you are in async mode 99% of the time:
Minimum BPW Hyst Value 13008.25 Usec
Minimum BPW 10919.00 Usec
RBob.
RBob.
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
