odd ball ecm?
Car: 92 c1500
Engine: 355ci
Transmission: 700R-4
odd ball ecm?
hey guys i happen to have an odd ball ecm #16146299 ($99), out of a 92' c1500, they only used this ecm one year, sadly i cannot datalog since winaldl doesnt support this ecm and i cannot find an ads file for tunerpro r/t. So i guess i have to switch over to a differnet ecm, my questions are will ecm #1227747 ($42) or #1228746 ($61) work with my application, i mean just plug right in, i dont want to have to re-wire anything or get a new wiring harness? My other question is if both of these are compatable, which would be the better one to use?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The 7747 and 8746, or similar ecms should be a direct replacement assuming that the 6299 is a C3 ecm.
Car: 1983 G20 Chevy
Transmission: 4L60
Winaldl should have no problem dataloging a 299. I did it for months with my 1992 G20 TBI setup in my 1983! Just use the 1227747 or 8746 definition. They are very similar and one of the two (forget which) will give you all the pertinent info that you need. The 1227747 is a pin for pin replacement for the 299.
The 1227747 is probably the most widely hacked and tuned TBI ecm out there.
Car: 92 c1500
Engine: 355ci
ok cool i just figured i would have to have the exact ecm # in winaldl to datalog, cool ill just stick with my stock ecm them, thanks
sjorgens
Oct 1, 2015 07:54 PM
